Orbi WiFi 7 RBE973
Reply
Wont connect to amazon fire stick
Tracy76
Follower
The fire stick dose recognise rhe netgear wifi booster and i can select it ..but then a page on my tv pops up to join netgear and its blank and gives me no options ..so i go off the page ...and check network connections ..it says that the fire stick is connected with problems but wont let me access my shows as though its not connected
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Wont connect to amazon fire stick
Hello Tracy76
Are your trying to connect to a routers network or a extenders network also what is a model of the netgear product.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2908 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
