JustMakeItWork2's avatar
Jun 01, 2022
firmware update V10.01.07
I have a CM1000V2, upgraded to firmware V10.01.07 via my IPS. Now I can't access the modem GUI via wifi on any browser, any device. Was directed to use Ethernet between PC and modem. This worked, but I'm not going to do that every time I need to log into my modem. Any ideas?
  • FURRYe38's avatar
    Try 192.168.100.1?
    What is the brand and model of the host wifi router connected to the modem?
    Try a factory reset and setup from scratch. Press the reset button for 10 seconds then release.
    If this still happens, contact that ISP about this.
    Who is your ISP?
    • JustMakeItWork2's avatar
      JustMakeItWork2
      Initiate
      orbits rbr50. 192.168.100.1 does not work. time out via browser. using terminal, i get one valid ping response, then endless Request timeout for icmp_seq. reset to factory settings, still not connecting via wifi. was there a change in v10 that would have caused this?
      • FURRYe38's avatar
        Take the RBR50 out of the mix and just connect 1 wired PC to the modem.
        Who is your ISP?
  • FURRYe38's avatar
    Any progress on this?
    • Steve0617's avatar
      Steve0617
      Tutor
      Read my linked post.
      Create a static route. Worked perfectly for me.
      I'm assuming they removed the direct route we're used to on purpose. I'm not waiting around for them to restore it.
      • FURRYe38's avatar
        Let's see what the OP has done.
