- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
remove, disable shareready on C7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have just installed a Netgear c7000 cable model and wifi router and want to remove, or disable, the default Readyshare feature. This is unneccessary for my environment
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great to hear. Glad that worked. Thanks for sharing. Mark your thread as solves so others will know.
Enjoy,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: remove, disable shareready on C7000
There should be a menu option to uncheck and disable that feature on the modems web page.
Review the user manual to see about this feature.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] C7000
C7000[v1] or C7000v2? Look for "Model" on the product label.
> [...] want to remove, or disable, the default Readyshare feature.
What leads you to believe that the ReadySHARE feature is enabled
now? Did you connect a USB storage device (or printer) to the
C7000[vX]?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for a
topic like 'Share USB Devices Attached to the Modem Router". Read more.
Panic less.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear was defaulting to the "Basic" option for ReadyShare. So, I downloaded Netgear's USB Control Center and unchecked "Run Basic when windows is active". That did the job.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy,
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
