Orbi WiFi 7 RBE973
Reply
unlocked channels means?
softciy
cm-1000 Netgear modem What is causing these? Is this a normal profile, anything out of th ordinary?
Message 1 of 6
Guru
Re: unlocked channels means?
Some isp's setup would leave channel 32 unlocked and lock in the ofdma channel.
Are your speeds ok?
Your signal doesn't look to bad but look like a few channels might have a little interference. Nothing thats horrible but you could always check your splitters/cable/connections to optimize.
Message 2 of 6
softciy
Thanks for the reply.
Speeds are excellent.   200Mbits down, 7Mb up (pretty close to what we pay for)
What about the unlocked Upstream?  There is 4 unlocked, shouldnt that be all unlocked UP?
Message 3 of 6
Guru
upstream is your upload. its standard for 3-4 to be locked to hit upstream speeds.
Message 4 of 6
softciy2001
I meant shouldnt they ALL be LOCKED upstream?
Currently 4  of the 8 are locked.
Also , isnt the netgear cm-1000 supposed to be  32 down and 16 up??
Message 5 of 6
Guru
usually not all are locked on upstream. Upstream is much slower as evidenced by your 5mbps upload. should carriers add more upstream capability, they can lock more channels or even use the ofdma channels on docsis 3.1 devices.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1600 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
