Coveno
Jul 27, 2021Aspirant
2.4 GHz radio is not working
Was working fine, now suddenly the 2.4 GHz radio is not working, the 5 GHz works fine. I've tried turning the radio on/off both manually and via logging into the router on an ethernet connection. All the settings seem to be correct, as they were prior to this issue. But still no luck. Any suggestions? Thanks!
Try a factory reset on the modem and setup from scratch?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz.
Any Wifi Neighbors near by? If so, how many?- CovenoAspirant
Hi
What channels are you using? Auto? YES
Try setting manual channel 1, 6 or 11 on 2.4Ghz DID that, no joy
Any Wifi Neighbors near by? If so, how many? TWO , not new
Will look in to it and try reset later, woried I will lose everything.
Resets only erase user configurations and sets back to default values is all. Sometimes this can help correct problems.
After the reset, I would pull the power from the modem for 30 seconds then plug back in. Then walk thru the setup wizard for the modem.
