- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Atrocious packetloss on CAX30
- Mark as New
- Bookmark
- Subscribe
- Permalink
i'm having terrible packetloss on ALL devices. restarted modem, factory reset modem and still nothing. has been like that for a week. isp was useless saying it is my fault but the modem is ok.
I unplugged everything from the modem besides my computer and nothing changed. My speed tests should be gigabit but are abominable even though actually downloading stuff seems fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Atrocious packetloss on CAX30
the pictures don't seem to be showing up see here is this instead https://imgur.com/a/qLEwjEX
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your power levels are out of spec and you have a ton of errors.
Remove any splitters, amplifiers, or signal attenuators from your line.
Check your line for cheap cables, extended runs, bad/old/cheap/corroded ends and replace them.
Preferrably move the CAX to right where the coax comes into the home and direct connect there.
If that doesn't help, the ISp will need to check the line
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok but last thing i want to add if it means anything, that Acquire Downstream Channel number was different before the factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
the frequencies used can change. That's sometimes where we run into issues because there will be line issues but when a user opens the "cable connections page" it might be on a good chuck of bandwidth and not look bad. But you open the logs and you see issues. You've got them on the cable connections page already.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok so the guy came and the person who set my internet up previously(contracter, not employee) screwed up and BENT the coaxial cable coming to my house and it was the reason. HOWEVER he stilll sees issues w/ noise and another guy is coming out. hopefully they don't need to tear up the ground to fix it. And i am seeing dips still as well.
However i just wanted to ask one more question since it seems to be fixed most of all.
In ping plotter i have seen like 50% packetloss but to the MODEM itself. does that mean the modem could be defective? It isn't like this all the time but still the modem is a 5 feet away from me.
right now i opened the modem page and it hit like 7% and it keeps going up. 12% right now. is this a glitch or what?
- Mark as New
- Bookmark
- Subscribe
- Permalink
got the screen snip from this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't paid attention and know if it is just me accessing the modem page or it gets worse when i access the modem page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know your initial post didn't have any packet loss. Anything change since the inital post?
Are you on wifi?
Hardwired?
Different device?
- Mark as New
- Bookmark
- Subscribe
- Permalink
nothing besides factory reseting it like twice and changing different outlets.
always on ethernet and same pc.
it seems to very slowly creep up by like .4% each time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
have you tried a different device?
Tried changing the cable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
just changed the ethernet. same.
not other computers i can test it on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
wireless devices don't have the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
how do i find out? don't think there is ping plotter for mobile
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not sure what to tell you.
Its tough when you're only testing on one device to determine if its a router issue or that specific device issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok i just realized the cord i used was plugged into my router that was plugged into the modem.
The router has no PL and the modem now i have no packet loss to.
EDIT: nvm now it is having PL to router and modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok i was able to do it on my phone. same issue with packet loss.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't know the relation between a traceroute to an overseas site, and where you suspect terrible packet loss. Here an ad-hoc check originating from Switzerland - where two hops seem to add latency (from Paris to Virginia US, addign about 80 ms total ~100 ms) and then through the US (from Virginia to LA, adding about 50 ms, total ~150 ms) and last but not least from California to Japan (LA to Tokyo, plus 100 ms or more, total ~250 ms):
9 8 ms 8 ms 8 ms i00mil-015-ae0x40.bb.ip-plus.net [138.187.130.31]
10 9 ms 9 ms 9 ms 193.134.95.251
11 9 ms 10 ms 9 ms ae-1.r20.mlanit02.it.bb.gin.ntt.net [129.250.3.84]
12 19 ms 22 ms 19 ms ae-10.r21.parsfr04.fr.bb.gin.ntt.net [129.250.4.188]
13 97 ms 100 ms 98 ms ae-13.r24.asbnva02.us.bb.gin.ntt.net [129.250.6.6] <<< F <-> VA, +80 ms
14 97 ms 96 ms 96 ms ae-0.r25.asbnva02.us.bb.gin.ntt.net [129.250.2.36]
15 149 ms 149 ms * ae-2.r25.lsanca07.us.bb.gin.ntt.net [129.250.3.189] <<< VA <-> CA, + 50 ms
16 263 ms 280 ms 260 ms ae-12.r31.tokyjp05.jp.bb.gin.ntt.net [129.250.3.192] <<< CA <-> JP, +100 ms or more
17 249 ms 248 ms 249 ms ae-3.r00.tokyjp08.jp.bb.gin.ntt.net [129.250.6.129]
18 250 ms 249 ms 249 ms ce-0-8-0-1.r00.tokyjp08.jp.ce.gin.ntt.net [203.105.72.158]
19 * * * ...
20 251 ms 252 ms 251 ms 158.205.95.54
21 * * * ...
22 252 ms 251 ms 252 ms 210.140.92.180
Friendly reminder: ISP and carrirer backhaul routers have more important jobs to do than handle IGMP.
There might be something wrong. But then, the ISP says the modem is OK ... and that's the CAX30, isn't it?
Probably Gigabit on the downstream, indeed one could expect higher numbers.
The amount of correctable, and much more the uncorrectables on the RF link (the cable modem part) are just ridiculous.
- Mark as New
- Bookmark
- Subscribe
- Permalink
on my pc? yes. disabling it now did nothing either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
what? this part was already solved lol
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting, this was drafted and posted a longer time ago 8-/
