- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
BRIDGING ISSUE WITH C7100V NIGHTHAWK AC1900 WIFI CABLE MODEM ROUTER
- Mark as New
- Bookmark
- Subscribe
- Permalink
The above model with the most updated firmware version of V2.01.30 Cannot be bridged. After numerous calls to netgear support, i was finally told by a Linksy's tech, who went above and beyond for me, that this model number cannot be bridged , that it does not have a NAT mode. The Time spent in order to find out the realization that this model cannot be bridged has been an extremely frustrating one. I even had a netgear manager tell me to downgrade my FirmWare Version. I am wondering can someone recommend a Modem/Router (that has phone/voice capability and ports) that is just as good or better than this model? Or Does Netgear offer another model that can be bridged?
Any advice would be greatly appreciated.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BRIDGING ISSUE WITH C7100V NIGHTHAWK AC1900 WIFI CABLE MODEM ROUTER
Have you tired "NAT MODE OFF" setting? it should be there in Advance GUI page.
also, there is new product out CM500V with voice and it is just a plain bridged modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. i did try that. And that is the issue.. There is no NAT mode on this model. with the firmware that i mentioned above.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm in bridged mode with a C7100V and Firmware Version 2.01.30, so it definitely can be done.
Try Advanced > Administration > Router Mode
Check "No".
- Mark as New
- Bookmark
- Subscribe
- Permalink
"NAT MODE OFF" worked in V 2.01.23, but it was changed in 2.01.30 as I described elsewhere.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry, I dont see any attached picture. it may our forum issue. It is best if you attach option or just use 3rd party website such as imgur.com
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting - I did see the picture. Nevertheless, I'll try to attach it here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Definitely a forum issue. I can see the screenshot with MS Edge and Firefox, but not with Chrome.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see the screenshot.
are you saying when you choose NAT mode = NO and apply, it still does not get into bridge mode?
Who is your ISP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Who is your ISP?
"NAT mode" is no longer an option in 2.01.30, just as the OP said in Message #3.
I originally bridged the C7100V under 2.01.23, and in that firmware, setting "NAT mode" to "No" bridged the gateway. When the firmware updated to 2.01.30 (pushed by Comcast in the dead of night, without my knowledge), I found the interface had been changed, and now I have "Router Mode" "Off" instead.
The only ISP supported by the C7100V is Comcast/Xfiinity. But being a Netgear employee, you already knew that, right? 😉
- Mark as New
- Bookmark
- Subscribe
- Permalink
router mode-off = Bridge mode = NAT mode-off (they are all the same).
are you having trouble getting this to work, if yes, please PM me.
yes, I asked about ISP since I have seen people buying for other ISPs such as TWC, CableVision/Optimum, etc and expecting it to work. Yes, Only Xfinity is supported.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just bought a Netgear C7100V cable modem to use with Comcast Network.
What i did to get it to work in Bridge mode is: In configuration mode go into advance look for gateway, there is another (options or check box right beside the Gateway.
Move over from Gateway check box to the next, that will put you into bridge mode.
save your settings.
My problem now if i used 192.168.100.1 or 192.168.0.1 I'm not been allowed to get back into the modem.
After setting your modem to Bridge mode you have to boot both Router and switch.
I'm using Cisco 1941 Router and a Cisco 3560 Switch.
good luck.
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
