- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Buying a cable modem with voice for Comcast
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am currently using an ARRIS SB6121 Cable Modem with a Netgear R6200 Smart WiFi Router. Comcast shows that my cable modem is not supported so I'm looking for one that is. I recently upgraded my comcast to Triple Play with Voice, so the recommended modem is a Netgear C7100V. When I search to purchase this modem, the recommendations are to purchase Netgear Nighthawk AC1900 (24x8) DOCSIS 3.0 WiFi Cable Modem Router Combo. But, since I already have a very decent Netgear Router, why should I purchase the combo? I can't seem to find just the Netgear C7100V
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
wait for CM500V to be in stock and use that with R6200 router you have.
CM500V is modem-only + Voice device (no Router + WIFI).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Buying a cable modem with voice for Comcast
> [...] Netgear Nighthawk AC1900 (24x8) DOCSIS 3.0 WiFi Cable Modem
> Router Combo [...]
Not a model number, is it?
> [...] I already have a very decent Netgear Router [...]
Also not a model number.
> Model: R6200v2|AC1200 Dual Band Gigabit Smart WiFi Router
Is it that?
> [...] I can't seem to find just the Netgear C7100V
Visit http://netgear.com/support , put in your prospective model
number ("C7100V"), and look for Documentation. Get the User Manual.
Read, to learn what you think that you want really is.
On the bright side, you could probably configure your existing "a
very decent Netgear Router" as a wireless access point, and use it to
improve your wireless coverage. (Look for "Wireless Access Point" in
the R6200v2 User Manual, for example.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, this is one that I saw was listed as compatible, but I couldn't find a place to order it. As you indicated, it's "Temporarily out of stock". I placed an order via Amazon.com and I guess I'm on a holding pattern until there is a product available to ship. Thank you very much vkdelta.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your answer was not useful, however vkdelta (Netgear employee) did provide the answer I needed.
