- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C6300 WPS process succeeds but no client shown in attached devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
while attempting to attach a dlink camera using WPS the process is done as follows:
I push the softwre button in the wps wizard, then go to the cam and push the client wps button.
The router displays a successful conection and shows the mac address of the camera. When I try to check my attached devices the camera is not in the list. Also downloaded wnetwatcher and it does not appear there either. I need to access the cam to configure a port and port forwarding so I'm at a loss. It does work if I use a cable rather than wireless to connect to the cam configuration page.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did a total reboot of modem/router and all is ok now.
WPS working as it should. Thanks for suggestions
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C6300 WPS process succeeds but no client shown in attached devices
What happens if you connect the camera to the modem using the WiFi SSID and PW?
- Mark as New
- Bookmark
- Subscribe
- Permalink
if I could determin the ip that wps assigned I could try that. I just may have to use cable on all my cams to setup on wireless
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try to set up the cameras via wired connection with the wireless ssid and PW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
