schatzi
Jul 02, 2020Follower
C6300-no internet connection
I had a Netgear router/modem that has worked for the past year and a half. Yesterday, it no longer showed up in my network options. Contacted my internet provider and they said it was the router/modem. Bought a new router/modem today and cannot get it to connect to the internet. Any ideas?
- olympos1625NETGEAR Employee Retired
Hi schatzi,
Good day!Welcome to NETGEAR Community!
We would need the following information, so I can offer you additional recommendations:
1. What is the model of the new modem that you purchased?
2. Did you contact your Internet service provider already to provision the new modem?
I look forward to your response.
Oliver
Community Team - plemansGuru - Experienced User
Did you buy the C6300?
If you have any splitters, amplifiers, or attenuators in line, remove them.
I'd also move the modem/router to right where the coax enters the home to ensure it isn't a wiring issue internal to the home.
Are you abel to access it via a hardwired (ethernet) connection?
If so, get a screen snip of the cable connections page and logs.
