Time Priority Description 1970-1-1, 00:00:38 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:44 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.0;CM-VER=3.0; 2016-9-10, 10:37:19 Critical (3) Resetting the cable modem due to docsDevResetNow 1970-1-1, 00:00:37 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:44 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2016-9-14, 13:17:42 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 1970-1-1, 00:00:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:41 Notice (6) WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:41 Notice (6) WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INTERFERENCE 1970-1-1, 00:00:46 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:49 Notice (6) Honoring MDD; IP provisioning mode = IPv6 2016-9-14, 13:52:40 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:52:44 Warning (5) MDD message timeout;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:52:45 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:52:51 Warning (5) MDD message timeout;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:52:52 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:54:04 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:54:05 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:54:36 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:54:38 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:54:42 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:54:43 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:54:48 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:54:50 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:54:55 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:54:56 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:55:01 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:55:11 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:55:13 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:55:14 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:55:15 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:55:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:55:24 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:55:25 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:55:26 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:55:28 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:55:32 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:56:01 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=50:6a:03:7f:2f:b0;CMTS-MAC=00:01:5c:72:62:69;CM-QOS=1.1;CM-VER=3.0; 2016-9-14, 13:56:51 Notice (6) Honoring MDD; IP provisioning mode = IPv6
