SR_0410's avatar
SR_0410
C7000V2 - Spectrum Cable - every night resetting at same time
I have spectrum cable - ARRIS TM602G modem with C7000v2 nighthawk modem/router combo.   Every night at 12:15AM  my wifi goes off line for couple of minutes.
My event Log shows:
- Resetting the cable modem due to docsDevResetNow
other logs verbiage has:
SYNC Timing Synchronization failure - Failed to acquire FEC framing;
No Ranging Response received - T3 time-out;
Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
Missing BP Configuration Setting TLV Type: 17.8;
This in general would not be an issue given the time of day - but while all of my devices reconnect with no issues - I have  4 Ring cameras - where 2 of them will reconnect and 2 will not reconnect until 12 hours later, then they reconnect automatically.
3 variables -  NIghthawk, Spectrum Cable and Ring cameras.
Starting point is the 12:15 AM event log - so trying to determine if this is a spectrum issue or  Netgear router issue.  Of course spectrum says the netgear is defective.
I have hard re-set the nighthawk multiple times as well as cameras, etc. and  to no avail.  The  events happen like clockwork and cannot find the root cause.
appreciate any ideas.   thanks
  • plemans's avatar
    i guess I'm curious as to why you're using 2 modems.
    • SR_0410's avatar
      SR_0410
      Either rent spectrums router for ridiculous monthly charge or get my own - which I did with the nighthawk.   Worked fine for about 6 months, till recent issue.
      • plemans's avatar
        so you're not using the other modem? Just the c7000?
        Do you have a screen snip of the cable connections page and the modem event logs?
