Akiha
May 23, 2022Guide
CAX30-100NAS Intermittent Connection drops/poor upload/error in log
Netgear Nighthawk AX2700 (I can't find this model on the drop down, but it's what amazon says it is)
Hello, I've been having an issue with my upload speeds during the night (9pm - 3am). While streaming to twitch, my connection will drop and the stream will "buffer". During this time, my bandwidth to OBS will be reported as between 0kbps - 2kbps. This will jump to over 10000kbps every now and then but will quickly return to near zero. This will continue for a bit and then recover. Any ideas as to what's going on?
For reference, I've been dealing with this issue for 5 months or so.
It has been getting worse over time.
Attached are my upstream/downstream.
Error logs: 2022-05-22 22:31:19Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;
2022-05-22 22:31:24Warning (5)REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value; CM
2022-05-22 22:31:24Warning (5)RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW
2022-05-22 22:31:24Warning (5)Dynamic Range Window violation
2022-05-22 22:31:24Warning (5)RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;
2022-05-22 22:43:28Critical (3)SYNC Timing Synchronization failure - Loss of Sync;
2022-05-22 22:43:30Warning (5)DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;
These errors occured at the same time as one of my connection losses.
