PatTestsys
Dec 16, 2021Aspirant
CAX80 - backup with 5g
Anyone have any suggestions on how to configure a backup mobile device with Nighthawk AX6000 DOCSIS 3.1 WiFi 6 Cable Modem Router (CAX80)? My Comcast provider is unreliable, and I have no other broadband options.
You mean like having a backup ISP service?
Is that what you're asking?
If so, that model doesn't support failover or dual wan.
- PatTestsysAspirant
Yes, that is exactly what I am talking about. I think I found a solution with the new Orbi 5G system. I can hook that to my cable modem, and it will failover to 5G when the cable modem fails. Also supports 2 additional gigabyte lan ports, which I need. I currently use an eero mesh with my CAX80 (the CAX80 is great wifi, but doesn't cover my third floor), so this would replace that component. Pricey though.
So both CAX80 and Orbi don't support cell signal services. 5G or 5Ghz on NG products means a 5Ghz wifi signal. Not the 5G or 5th Generation cell services. Orbi as a LTE cell service product The LBR20 series.
