- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CG3100D-2BPAUS Cable gateway/router - Port Forwarding problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been using port forwarding for ages with this gateway/router with no problems. However just recently I created a new forwarding rule with the same name as an existing one. The router did it without complaint, but something has gone wrong because I cannot now delete the last entry in the forwarding table. I can delete all the others, but the last one will not go. I presume I could clear this by returning the router to factory settings but I really don't want to do that - for a start I do not know what the admin password would be reset to, as I do not have a manual. If anyone has come across this and knows how to get past it without a factory reset, I would be very pleased to hear from you.
The router's hardware version is 2.02. Its software version is 5.5.7.mp2.V2.06.07.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CG3100D-2BPAUS Cable gateway/router - Port Forwarding problem
the default login in after a factory reset is admin/password.
DarrenM
