Roger313's avatar
Roger313
CM1000 v2 Modem drastically slows down my speed
Ive been having issues with my modem ever since i bought it. My plan that i pay for with comcast is 300mbps download/ 10 mbps upload. Ever since i bought this modem my speeds are drastically slower, especially the upload. I currently have a max upload of 150mbps and 0.8 kbps upload. I called comcast and they replaced everything outside with new wires and i have a cat 6 lan so its not that either. I checked the modum event log and have gotten alot of critical errors and netgear support is no help because they said i need a laptop or computer with a ethernet port, which i dont have.
  • plemans's avatar
    Log into the modem and get the cable connection page too.
    if you have any splitters, amplifiers, attenuators hooked to the coax line, remove them. hook the modem to right where the coax enters the home.
    • Roger313's avatar
      Roger313
      Part 1: I’ve checked for that and cant find any.
      • Roger313's avatar
        Roger313
        Part 2
