- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM2000 Flashing Upstream Light
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I just installed a CM2000 modem and the upstream light is constatnly flashing. It is working fine, I am getting my plan speeds (900/20 Mbps). Is this something I should to contact Xfinity about? I know it works fine now, but will there be a problem later?
My Logs are attached.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: CM2000 Flashing Upstream Light
I see you have lots of Critical 3's in the logs.
You might contact the ISP and have them check this.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem | Wifi Router Orbi RBK853 (Router Mode), Wired Backhaul and RBK752 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Is the ISP service box where the cable enters my house? I have a MoCA splitter there with a POE filter. Would that be the cause of the errors?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Could be. A test you can try, temporarily remove this connector and directly connect the cable to the other side for a more direct connection with the modem. See if the Uplink LED continues to blink or not.
