inky_thoughts
Jul 31, 2020Tutor
CM500 Cable Modem Creating Double NAT
Setup: CM500-100NAS on Firmware v1.01.05 Cable Modem
Ethernet out to eero Gateway wireless router
Xbox One five feet from router, connected wirelessly
For a couple weeks, I've shown a strict NAT on the xbox, which affects some of the games I play (peer to peer connections). The xbox states UPnP not successful. I worked with eero support and nothing worked to fix it, not even portforwarding everything for the xbox.
Their tech support ran a diagnostic and said I have a double NAT, and it's not the eero, but my other router (implying I used a modem/router combo, which I do not).
For my own research, I switched to an old wireless router (Netgear WNDR3400v2) and got the same proble with a strict NAT. This time the Xbox stated "double NAT detected."
To my understanding, a double NAT would mean I have NAT happening on the modem as well as the router. But, my modem is not a router and has no network translating options baked into the settings. There are no other routers or swtiches on the network. It's modem to wireless router to device.
Anyone have ideas as to what is going on? I'm wondering if it's something jacked up on the ISP side.
> [...] a double NAT would mean I have NAT happening on the modem as
> well as the router. [...]Well, somewhere, but a modem can't do it. Another possibility:
https://en.wikipedia.org/wiki/Carrier-grade_NAT
> [...] I'm wondering if it's something jacked up on the ISP side.
Carrier-grade NAT would qualify.
Have you looked at the IP address of the WAN/Internet interface on
your router? Plug that address into the form at:
https://whois.arin.net/ . Is it a public address or a private address?
What happens if you directly connect the xbox to the modem, with out any router in the middle?
Press and hold the front power button on the xbox until it turns off then release. Then turn it back on.
You might also try changing ports manually on the xbox as well, see the xbox networking get into a bad state. Change to something else in the xbox drop down menu under advanced settings under networking.
- Thanks for the suggestion.
When I directly connect the Xbox to the Ethernet out from the modem, it still has a strict NAT. In detailed network statistics on the Xbox, it says my network is behind a port-symmetric NAT.
And that’s direct from the modem.- FURRYe38Guru - Experienced User
Power OFF the modem for 1 minute then back on.
You might also try changing ports manually on the xbox as well, see the xbox networking get into a bad state. Change to something else in the xbox drop down menu under advanced settings under networking. I have done this a few times then got OPEN NAT after the change.
IF this doesn't change anything, I would check with the ISP to see if anything is happening there. Possible xbox service issue as well though I doubt it,
https://whois.arin.net/ . Is it a public address or a private address?- That’s really helpful. Everything seems to point to a carrier-grade NAT system.
Using whatsmyip.org and Whois, my ip from my ISP is not the same as the ip on my router.
Looks like I’m up the creek. - Final update. With the knowledge I got here, I worked with the ISP. They confirmed they use a network NAT and they needed to “open the NAT” for me. I pieced together they had done upgrades on the area which may have defaulted a previous passthrough.
After they pushed a fix, I had a moderate NAT and I could then port forward the Xbox ports to get an open NAT.
Thanks for the advice!- FURRYe38Guru - Experienced User
Glad you figured it out and got it working better.
Enjoy.
