pauliw25's avatar
pauliw25
CMD31T - All green lights - no internet
Recently I returned my defective Netgear CMD31t modem to Netgear.
This week, a refurbished replacement arrived.
Problem:
When I connect the replacement modem to my desktop computer and my Time Warner internet cable - the modem shows all green lights. However, in Windows 10 for the Ethernet connection, all I get is a NO INTERNET message.
I am sure there is some type of setup procedure that needs to be done to fix this. Could someone please tell me what I need to do?
I have not been able to find a modem Manual (even online) that helps.
Note: I am a novice when it comes to stuff like this so please explain things in basic terms.
  • pauliw25
    I do not know if you have done this yet or not since its a replacement modem Time Warner cable has to re provision the modem and make sure its enabled in there billing system on you account so I would call there Tier 3 tech support have them check and see if they can communicate properly with the new modem.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello pauliw25
    Do you have a router that the CMD31T is connected to? also try another cord could be a bad cord.
    DarrenM
    • pauliw25's avatar
      pauliw25
      No - the WiFi router is connected to the Ethernet modem. Not the other way around.  The Ethernet router CMD31T is directly connected to my Time Warner internet cable.
      My Windows 10 desktop is connected to the modem via an ethernet cable - the same cable that worked with the original CMD31T modem.
      In seeing that I am using the same cable that worked before - I serously doubt it's the cable, and to be honest - in seeing that I live on a limited budget - I would prefer to avoid purchasing a new cable when most likely the problem is not with the Ethernet cable.
      • DarrenM's avatar
        DarrenM
        pauliw25
        DarrenM
