Orbi WiFi 7 RBE973
Reply
Correct setting for "Disable port scan and dos protection" in C3700
FTinDFW
Hi Expert,
What should be the correct setting for "Disable port scan and dos protection" from
Advanced>WPS Wizard>Setup>WAN Setup
After I did a factor reset, The box is checked in "Disable port scan and dos protection".
I see from Log all the time that have these entries:
[DoS attack: Teardrop or derivative] from 139.12.155.0, port 0 2
[DoS attack: Ping Of Death] from 139.12.155.0, port 0 2
Should I un-check the "Disable port scan and dos protection"?
My device is Netgear C3700 Cable Modem Router with WiFi
Thanks for your help.
Frank
Model: C3700|N600 Cable Gateway Docsis 3.0
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Correct setting for "Disable port scan and dos protection" in C3700
Yes you will want to un check the box so it is enabled.
DarrenM
Message 2 of 4
FTinDFW
Thanks to your response. I'll try iy out and hopfully no more
[DoS attack: Illegal Fragments] from 139.12.155.0, port 0
Have a great weekend.
BR//Frank
Message 3 of 4
FTinDFW
No matter I check or un-check this setting. This entry still exist from time to time to differebt target address(all over the world - USA, Europe, south america, ...
Target IP:
72.106.126.106:0
181.235.103.18:0
65.197.193.196:0
136.227.151.143:0
108.217.98.8:0
1.252.34.44:0
Source always this 139.12.155.0, port 0.
Any comments and suggestions is appreciated.
Thanks
Frank
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 6346 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
