Orbi WiFi 7 RBE973
Reply
Disable factory reset on Nighthawk C7000 modem/router
desparate
Is there a way to disable the factory reset button? Unless the router is physically secure, any person (minor but smart family members) can reset the router and connect to the internet bypassing all security features programmed in the router.
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 8
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Disable factory reset on Nighthawk C7000 modem/router
Hello Desparate
Yes you can just turn off broadcast the SSID and on your devices you will have to use the manual connect option and enter the name of the SSID.
DarrenM
Message 6 of 8
All Replies
netwrks
Master
Short of cutting the wires on the reset button, the answer would be no. Another alternative is take away the minor's devices...
Message 2 of 8
desparate
Or just remove/scratch the password info label from the box before first installation. Too late for me now but hope it is useful for others having a similar problem.
Thanks for the reply.
Message 3 of 8
VE6CGX
Master
Couldn't cover the reset switch with thick piece of tape?
Message 4 of 8
desparate
No tape will keep away the pest I have! I rewired the cables and moved the router to a different room out of sight. Let's see how long this would work since the location can be traced through the signal strength now. Is it possible to connect to a network without advertising it's name?
Message 5 of 8
DarrenM
Hello Desparate
DarrenM
Message 6 of 8
desparate
Great. This seems to be working now. Thanks a lot for the help.
Message 7 of 8
desparate
Message 8 of 8
Discussion stats
  • 7 replies
  • 5049 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
