aara
Feb 20, 2016Tutor
Internet through modem works, but not through router
Greetings,
I do not have the disc that came with this router; I recently moved into a new apartment and got internet set up with Time warner.
When my ethernet cable is pluged into the modem from my PC, I can get internet just fine; but when I connect to the router (the ethernet cables are connected to the right ports, the cable from the modem goes into the yellow port on the modem and the PC is plugged into one of the lan ports), windows says it needs to find drivers and cannot install the drivers because I do not have the disc. I tried using setup wizard by logging into my router at routerlogin.com (or net?) but it still cannot detect an internet connection. I also tried updating my firmware version but I think the problem is having drivers for the router on my computer.
I have browsed netgear's site and could only find firmware updates, does anyone know where I can get drivers for my router?
- aaraTutor
Also my router is an N150 WNR1000 v3
Your modem may be locked onto the MAC address of your computer. You can try rebooting the modem while the router is plugged into the modem to see if the modem will migrate service to the router. If that doesn't work, then try cloning the MAC address of your computer to the router. You can do this by logging into the router and go the Router MAC Address setting. Select either Use Computer MAC Address to automatically pick up the MAC address from your computer or Use This MAC Address and enter your computer's MAC address manually. Click Apply to save the setting. You may need to reboot the router before the change will take effect. Test Internet connectivity.
- aaraTutor
Thank you,
Whoever in the future has this issue, what TheEther said worked
