BeeVee
Dec 31, 2015Follower
N450 disconnects every hour
Hello,
Been having issues with my N450. For the past month its been disconnecting me from my online gaming about every hour. Doesn't matter what game I play, it resets the connection. The console is hardwired to the router itself. I have a feeling it has something to do with my DHCP settings, but I could use some help figuring that out. Talked to my ISP, they said it all looks good on there end. Any help I can get would be appreciated.
- DarrenMSr. NETGEAR Moderator
Hello BeeVee
Are you connected on wireless or hardlined? if wireless try changing your wireless channel.
DarrenM
- jkerplayAspirantI have the same model and mine has the same issue. Mine is hardwired. Any idea why it disconnects?
jkerplay
I would check all your connections make sure its not a bad cord also if you have a cable splitter I would check that may even want to remove it and see if the connection improves. The last thing you could try is a factory reset. If all that fails you may want to contact netgear phone support if the modem is still under warranty.
DarrenM
