MartyGraw's avatar
MartyGraw
Initiate
Feb 21, 2022
Netgear C7000v2 Slow wifi speed
I recently upgtaded my broadband plan (Breezeline formerly Atlantic Broadband) from 100mbs down 5mbs up to a blazing 600mbs down and 50mbs up. I am seeing those speeds on my wired connections. Unfortunately the wireless speed is 100mbs or less; even if i stand right next to the router!
  • plemans's avatar
    a couple things.
    1. you won't see 600mbps over wireless. wired you will
    2. there's a 2.4ghz band and 5ghz band. 100mbps is pretty fast for 2.4ghz. the 5ghz should hit faster speeeds.
    3. what band did you test on?
    4. what device did you test on? Have you tried other devices?
    5. since you upgraded you speeds, did you ever factory reset/reinstall? sometimes old settings can slow the speeds.
    • MartyGraw's avatar
      MartyGraw
      Initiate
      I did a factory reset on the modem.I was testing at 2.4G. I just tested at 5G next to the modem and I got 328mbs download and 50mbs upload. thanks for your help!
      • plemans's avatar
        glad it was an issue of the band connected to!
        If you mark it solved, it might helps others with the issue and prevents others from trying to fix it as well :)
