sfdurango
Jan 29, 2018Guide
NightHawk C7800 DoS Attacks
Having frequent DoS Attacks last couple months:
SYNC FLOOD or UDP SCAN or ECHO CHAR GEN
Netgear's brochure for this NightHawk C7800 says:
SECURITY
- Denial-of-service (DoS) attack prevention
However, it does not seem to be prevented! The basic problem is with WiFi disruption to service: My WiFi extender (NightHawk AC2200) drops devices (one gave mesages: need to log into net gear). At other times, my Amazon Echo (Alexa) says: having problems connecting to the internet. I've also lost access to my security camera. According to the log, theses "Denial of Service Attacks" are initiating from various places: Cypress, Russia, China, and a few from USA IP Addresses. I know these may be "spoofed" (?) [fake addresses] but some of them are consistent.
Q. Does anyone know what Netgear means by "preventing" such attacks? They do seem to be a continuing nuisance to me and my connected devices!
Here is log from this morning (1/29/2018):
[admin login] from source 192.168.0.2, Mon, Jan 29, 2018 09:27:21
[UPnP set event: AddPortMapping] from source 192.168.0.2, Mon, Jan 29, 2018 09:24:33
[Time synchronized with NTP server] Mon, Jan 29, 2018 09:24:19
V NOT SURE WHY ENTRIES BELOW ARE USING 1969 DATES ???? V
[DHCP IP: (192.168.0.36)] to MAC address 50:c7:bf:00:92:1c, Wed, Dec 31, 1969 16:01:55
[DHCP IP: (192.168.0.23)] to MAC address 7a:b3:b9:01:8f:fe, Wed, Dec 31, 1969 16:01:39
[DHCP IP: (192.168.0.12)] to MAC address 50:c7:bf:02:b7:5b, Wed, Dec 31, 1969 16:01:37
[DHCP IP: (192.168.0.37)] to MAC address f0:6e:0b:14:cd:08, Wed, Dec 31, 1969 16:01:24
[DHCP IP: (192.168.0.4)] to MAC address dc:ef:ca:c8:e2:40, Wed, Dec 31, 1969 16:01:21
[DHCP IP: (192.168.0.30)] to MAC address 80:d2:1d:1c:5d:52, Wed, Dec 31, 1969 16:01:19
[DHCP IP: (192.168.0.10)] to MAC address 34:d2:70:a4:94:40, Wed, Dec 31, 1969 16:01:19
[DHCP IP: (192.168.0.14)] to MAC address 60:02:b4:c9:52:a8, Wed, Dec 31, 1969 16:01:18
[Internet connected] IP address: 73.92.144.179, Wed, Dec 31, 1969 16:01:15
[DHCP IP: (192.168.0.25)] to MAC address b0:b9:8a:65:b5:17, Wed, Dec 31, 1969 16:01:11
[DHCP IP: (192.168.0.9)] to MAC address a4:5d:36:20:61:07, Wed, Dec 31, 1969 16:01:10
[DHCP IP: (192.168.0.11)] to MAC address 50:c7:bf:02:bf:6c, Wed, Dec 31, 1969 16:01:09
[DHCP IP: (192.168.0.2)] to MAC address 34:17:eb:af:0c:a9, Wed, Dec 31, 1969 16:00:52
[Initialized, firmware version: V3.01.38] Thu, Jan 01, 1970 00:00:07
^^^^^ NOT SURE WHY ABOVE ENTRIES SHOW 1970 AND 1969 DATES ???? ^^^^^^
REBOOTED MODEM/ROUTER MON, JAN 28, 2018 APPROXIMATELY 09:24:00
[DoS attack: Sync flood] from source: 5.8.18.77, port 65534, Mon, Jan 29, 2018 08:52:48
WHOIS Source: RIPE NCC, IP Address: 5.8.18.77, Country: Cyprus
[DoS attack: UDP Scan] from source: 113.96.223.207, port 58908, Mon, Jan 29, 2018 08:05:34
WHOIS Source: CHINA TELECOM, IP Address: 113.96.223.207, Country: China
[DoS attack: UDP Scan] from source: 185.94.111.1, port 48098, Mon, Jan 29, 2018 05:49:56
Location: Moscow, Russia - 185.94.111.1 is a static assigned Cable/DSL IP address allocated to HLL LLC.
[DoS attack: Echo char gen] from source: 139.212.93.68, port 57737, Mon, Jan 29, 2018 05:40:09
IP Address: 139.212.93.68 IP Location: CHINA
[DoS attack: Echo char gen] from source: 125.64.94.208, port 33868, Mon, Jan 29, 2018 05:18:56
125.64.94.208 ISP ChinaNet Sichuan Province Network Country China |
[UPnP set event: AddPortMapping] from source 192.168.0.2, Mon, Jan 29, 2018 05:16:12
[DoS attack: UDP Scan] from source: 185.94.111.1, port 35655, Mon, Jan 29, 2018 03:39:36
[DoS attack: Echo char gen] from source: 173.82.2.223, port 4545, Mon, Jan 29, 2018 02:42:16
173.82.2.223 CLOUDCONE, LLC UNITED STATES MINDEN, NEVADA
[DoS attack: Echo char gen] from source: 184.105.139.77, port 27033, Sun, Jan 28, 2018 22:12:02
184.105.139.77 HURRICANE ELECTRIC DENVER, COLORADO
[DoS attack: UDP Scan] from source: 155.94.89.58, port 43326, Sun, Jan 28, 2018 21:32:28
155.94.89.58 NODES DIRECT JACKSONVILLE, FLORIDA
[UPnP set event: DeletePortMapping] from source 192.168.0.7, Sun, Jan 28, 2018 20:54:03
[UPnP set event: DeletePortMapping] from source 192.168.0.8, Sun, Jan 28, 2018 20:53:59
[UPnP set event: DeletePortMapping] from source 192.168.0.37, Sun, Jan 28, 2018 20:38:33
[DoS attack: Echo char gen] from source: 45.63.59.155, port 4545, Sun, Jan 28, 2018 20:30:09
45.63.59.155 Vultr Holdings LLC Los Angeles, CA
[DoS attack: Echo char gen] from source: 52.73.169.169, port 45846, Sun, Jan 28, 2018 19:59:01
52.73.169.169 hostile Malicious Host Amazon Technologies Inc. Ashburn, Virginia |
- DarrenMSr. NETGEAR Moderator
Have you tried to remove all mobile devices from the network it could be happening from a app on a device. You may want to connect a device one at a time and check if these issues are happening as soon as a certain device joins the network again.
DarrenM
I finally figured out what's been happening (since January!) > A member of my household received an XBOX for Xmas and since my Nighthawk Modem/Router/Wifi comes with UPnP (Universal Plug and Play) enabled, he was able to "play". But apparently using XBOX LIVE (Thanks Microsoft) broadcasts MY Internet IP Address so let the DoS Attacks (aka DDoS) Attacks begin.
"Have you ever experienced a suspiciously well-timed connection drop while playing an online game? Maybe you were just about to round out that royal flush or take down the mid-lane tier 2 tower, when suddenly your ping spiked and it was game over. If that sounds familiar, there’s a good chance that the game that you’re playing was the target of a denial of service (DoS) attack."
What to do? So far I've read numerous articles and some suggested:
1) Disable UPnP and use port forwarding > So I setup Static IP for XBOX and forwarded (8) ports to it. Then the attacks were isolated -- all came in on port 80. So, I disabled port 80. Then "whack a mole" set in....attacks came in on Port 53 then 500, then 3544. Finally disabled ALL the (8) ports. Did that stop the attacks? Not on your life (or mine) !! Recall that once that XBOX connected to the Internet, MY IP address has been "out there". So,
after I disabled all ports at 6pm, 1st attack 6:15pm, then 6:51, then 7:32 then 8:56pm.
Attacks
(2) from RUSSIAN FEDERATION MOSCOW, MOSKVA
(1) from SEYCHELLES VICTORIA, ENGLISH RIVER
(1) from HURRICANE ELECTRIC – DENVER, COLORADO
Good new....haven't had any attacks since those 4.
2. Get a VPN -- but that could causing timing issues with game playing.
3. Use Blacklist to stop specific IP Addresses from accessing my computer.
Apparently Netgear has chosen not to provide this feature, at least in my Nighthawk C7800. My last 4 attacks came from IP addresses identifed in the past so it might be helpful to "blacklist" them. (I know the IP addresses may be "spoofed" (aka fake) but I've run out of options.
Will now leave my internet with PUnP disabled and no ports forwarded for the XBOX.
PS: I tried getting Netgear support BUT my support expired so I was advised to use "The Community" .... I'm resting for now, but plan on checking other "non-Netgear" equipment to see if others offer "blacklisting" as an option !!
- BlockIt311Aspirant
Curious. Do you have any wireless cameras on your network? Also, some chat apps can get through. we should talk because I am pretty sure I have a similar issue especially with a certain IP.
I do have (1) Wireless Porch camera. This is one of the locations on my LAN that has dropped off assuming as a result of a DOS attack. Most times now, my Amazon Alexa device states: "I am having problems connecting to the internet." When I check, I find that my main Wifi name (SSID) is missing (primary Wifi not discoverable on Wifi search) [I have 4 Wifi names: (1) for 2.4 (1) for 5.0 (1) for 2.4 extender and (1) for 5.0 extender). My recourse always is: reboot the router! I am still getting DOS Attacks (daily) but , so far, the noticeable disruption occurs only about once every few weeks! One noticable IP address that continually (Dos) attacks me is: Hurricane Electric LLC 184.105.139.105 Fremont, CA. So far, I'm just living with the occassionaly disruption!
- BlockIt311AspirantEnable ddos protection if it has it. If not you can always block the ip. Also try unplugging the repeater jus t Incase it’s contributing to the issue. Next time it happens do a packet capture with wire shark and email it to your isp. They may put it on their blacklist for you. Let me know what you find out and good luck.
