RobbieB9969
May 06, 2022Tutor
Nighthawk AX6000 Not working
Nighthawk AX8 AX6000
Model #: CAX80
I have noticed my nighthawk is not online. The power button is solid white, but none of my other icons green. I have tried a hard reset, but nothing has happened. The router is over a year old, so the manufacturer warranty has expired. Has anyone experienced this issue? I have Xfinity and they are not reporting in outages in my area.
Are you able to log into the device?
If so, do you have a screen snip of the cable connections page, event logs?
that helps check the connection. The CAX80 has a reboot cycle that will run if its not detecting a cable connection.
No I am not able to login on the app. However, my cable is working fine.
Not using the app. But using a web browser to access its IP address
