Orbi WiFi 7 RBE973
Reply
Power Adapter Replacement???
PDIGS44
Hi.
I must say, I'm very disappointed with Netgear's support when it comes to replacement information. I have a new CM600 Modem that I can't set up because my stepdaughter accidentally threw out the box which still contained the power adapter. I have shopped online, have gone to stores, etc. and no one has any information on replacing Netgear adapters. This is ridiculous! Ordering the right part should take less than 3 minutes. You would think a company as respected and popular as Netgear would have replacement parts for their products, or at least a page one could go to that would link people to the respective part. I'm actually considering not using or recommending Netgear anymore because of this very reason.... which makes the company look cheap and shady. I should have continued using the surfboards. Not sure why I changed in the first place. Change is not always a good thing.
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Power Adapter Replacement???
Hello PDIGS44
Here is a picture of the specs of the power bricks to help you find the correct one you need.
DarrenM
Message 2 of 4
supersender
I Plan to buy a Netgear CM 700 , But it will be used in India, Can anyone please tell me if the power adapter  can be used in 240V l , 50 Hz power lines . Most of the Netgear products i have bought have power adapter which specify 110/60 hz to 240v/50 Hz , I cannot find any mention of this on the netgear website in the technical specs
Message 3 of 4
DarrenM
Hello Supersender
I have a picture of the adapter that comes with this modem and it is the same as your other netgear adapters.
DarrenM
Message 4 of 4
Discussion stats
  • 3 replies
  • 5355 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
