Orbi WiFi 7 RBE973
Reply
Replacing Comcast XB6 Modem
Mindoc
Guide
I would appreciate advice on replacing my rented comcast xb6 router/voice/modem with equipment that I own.  I have not been able to find docsis 3.1 gigabit equipment. I think it is best to use separate internet and voice modems and a router and I've looked at the cm1100 but netgear says it is not compatible with cable bundled services. does this mean it wont work if i use a separate voice modem? If so, what do you recommend. thanks
Model: CM1100|Nighthawk Multi-Gig Speed Cable Modem—DOCSIS 3.1
Message 1 of 2
Guru
Re: Replacing Comcast XB6 Modem
Ask you ISP if the CM1150v is supported on there system...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1212 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
