mscluppy's avatar
mscluppy
Router causing static
I have an older model netgear router which has been working fine until I upgraded my model and now the router is interferring with our scanner and pager (my husband is a firefighter). I don't know if there is a way to change the channel on my router. I don't see anywhere that that is possible but whenever the router is plugged in, it is creating continual loud static.  Any help is appreciated.
Note: we have a smaller home so moving the router farther away from the scanner/pager isn't possible. Currently it is NOT in the same room and probably the farthest away.
Thank you,
MsCluppy
  • > I have an older model netgear router which has been working fine until
    > and pager [...]
       What was the "an older model netgear router"?  What is the "upgraded"
    model?
    > [...] I don't know if there is a way to change the channel on my
    > router. [...]
       Without a model number, neither do I, but it would be pretty normal.
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual.  Look for "channel".
    > Model: WPN824v2|RangeMax Wireless Router|EOL
       Is that your "older" one, your "upgraded" one, or neither?  As "EOL"
    might suggest, that's not a recent model.
    • mscluppy's avatar
      mscluppy
      I'm sorry I mistyped. I have a new MODEM from Spectrum. My router is older. I'm wondering if I need a dual ban router?
      Thanks,
      Mscluppy
      • antinode's avatar
        antinode
        Guru
        > [...] I have a new MODEM from Spectrum. [...]
           Think for a moment.  If you couldn't see any more than that
        non-description, then how much would you know about that gizmo?
        > [...] My router is older. I'm wondering if I need a dual ban router?
           With my weak psychic powers, I still know approximately nothing about
        what you have, let alone what you might need.  Do any of these gizmos
        have makers and model numbers?  Care to share?
