- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
cm600 xfinity T3 error then bufferbloat
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
i have blast pro (250down/10up) with xfinity in 94550. the cm600, firmware version shows V1.01.18, is connected to a ubiquiti edgerouter-x running latest 1.10.9 firmware. i use the smart queue to control bufferbloat very effectively and this setup has worked well until last november (2018). since that time, i get fairly regular T3 errors in the log, every couple of days. e.g. Started Unicast Maintenance Ranging - No Response received - T3 time-out;
the modem auto connects and we have internet. HOWEVER, bufferbloat is out of control UNLESS I reboot the modem. it can be a hard or soft reboot, but that fixes.
is this a known problem with the cm600's? prior to november last year, i never had to reboot. since november this has been ongoing. fortunately reboot fixes it. any ideas on what it could be? we know how helpful xfinity is.
thanks,
jeff
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: cm600 xfinity T3 error then bufferbloat
Noise in the line can cause t3 errors.
I would go through and check your connections and your cables first. A bad/cheap connection, splitter, cable will degrade signal.
It can be an intermittent failure or a failure that only happens when the signal is boarderline. Start with the easy stuff you control and can adjust.
Do you have a screenshot/snip of your connections page (download and upload)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
i've had 2 service call checking connector from the street to the house. signal levels are nominal.
we've done the basic trouble shooting. the timeouts are intermittent as i said.
not the errors. this is since a reboot 3 days ago, the last t3 error.
here's the down/up:
Frequency start Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Downstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Upstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Mark as New
- Bookmark
- Subscribe
- Permalink
persaonally i feel that it is plant noise. we had that years ago and was why i left comcast. but we came back because att was too slow. it's been good for nearly 2 years... not intermittently bad. but at least i can fix it.
i was hoping it might be a modem issue that could be fixed by firmware... i guess not?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your power levels are out of sync. Your upstream levels are a bit to high and your downstream is a bit to low. Your best download is just within spec and your worse is out of spec. Its imbalanced and out of spec. Here's a website with some basic specs that are easy to interpret.
https://pickmymodem.com/signal-levels-docsis-3-03-1-cable-modem/
Did you go through and check connectors, cables, splitters? I had a cable with water in it once that caused an imbalance. I would more your router to right where it comes into your house and connect there to see what your connections are. this reduces the chances of bad connections/wires/splitters causing the issue. If you move the modem, post back here what the signals change to.
- Mark as New
- Bookmark
- Subscribe
- Permalink
there's a splitter infront of the cm600 to feed the xfinity digital voice. i've removed that splitter and the levels are instantly better:
<tabindex=-1>Upstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
i'm not sure what to do about this... so next text is disconnect the voice modem and reintroduce the splitter...
- Mark as New
- Bookmark
- Subscribe
- Permalink
now with splitter but the voice modem is disconnected:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this at the point where it enters the house?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yep. it's a 1682g. i think there's a etma only modem that's approved by xfinity. might that help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would have to believe after seeing all this info that the modem is fine and its the signal coming in. If that's right where it comes into the housee, I'd contact xfinity (if thats who you use) and have a discussion about power/signal levels and having them check it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks. i'll post back...
- Mark as New
- Bookmark
- Subscribe
- Permalink
or run it for a bit without the splitter and direct to the modem and see how your t3's do and if you get more bufferbloat happening.
