BizLorax's avatar
Nov 18, 2017
"Does not support Remote Access"
I have enabled remote management on the router (C7000-100NAS): Https, port 8443
But on the android genie app I get a "Does not support Remote Access" when I attempt to enable remote access on my Motorola E4.
Is this a limitation of the phone?
Or is there some other setting I need to enable on the router for this to work?
Thanks,
Biz
  • > I have enabled remote management on the router (C7000-100NAS): Https,
    > port 8443
       This lets you use a web browser to access the router's management web
    interface.
    > But on the android genie app [...]
       That's not a web browser.
    > [...] I get a "Does not support Remote Access" when I attempt to
       Is the C7000 router compatible with the "android genie app"?
    Apparently not.
       Not if the C7000 router is not compatible with the "android genie
    app".
    > to work?
       No.  You need an app and a router which are compatible.  Or, you
    might be able to use a web browser on the phone to access the router's
    management web interface.
    • BizLorax's avatar
      BizLorax
      Star
      Does anyone know if the Netgear Genie android app is supposed to control remote access for the C7000?
       More details:
      On my Moto E4 phone I am using the android Netgear Genie app: version 3.1.36
      My C7000 router firmware is: V1.01.23
      The app does allow me to monitor and control nearly all other functions listed in the app when I am at home at my phone is connected to router via wifi.
      It is the remote access feature that I can't get to work.
      I also notice that the app will not let me register the router, get "registered failed" message.
      Beyond that the app works fine.
      Is there a tutorial somewhere that provides step-by-step instructions for using remote access via android Genie app?
      Specifically the problem I having is as follows:
      In the android Genie app, I see two ways to enable the remote access feature.
      1) From the main menu (blue & white screen) /remote access icon I get ot a screen with a "remote access" slider.  When I attempt to slide the button to enable remote access, I get the mesage: "Does not support Remote Access"
      2) From another menu (tap on my account name, get to the 3 lines menu, (black & white screen text screen) there is a "remote access" option, that leads to a Netegar sign in screen.  That leads to another screen and I am asked to select the router, but the C7000 is not listed (nor is anything listed) in the Device list.
      So two dead ends.
      Buttom line: It isn't clear to me if there additional setup steps I need to do to fully enable remote access or if the android Genie app isn't compatible with C7000 router.
      Any suggestions?
      Biz
      • antinode's avatar
        antinode
        Guru
              https://kb.netgear.com/24686/
           Apparently, the C7000 is one of the supported models.  (What do I
        know?)  Whether all the features work properly may be a different
        question.
        > Any suggestions?
           If you're in the warranty support window, a formal support request
        might be worth a try.
