× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
AC791L boosters and cradles...
dnyberg2
Follower
I read on the internet that DC112A cradles work with the AC791L from Verizon.  Any one know if this is true?
If not, do DC113's work with the AC791L?
Does anyone have an AC791L working on any cradle and if so which one's??
Does anyone have an AC791L working with any kind of cell booster and MIMO antenna?
If so, what MFG and model are you using and how much better does it do for you?
Does anyome know for sure how these cradles boost the Wifi signal?
If the two "accessory ports" on the unit are both for MIMO cell antenna operation, how does a cradle boost the Wifi Signal without a coax connection and or external Wifi antenna??
Thanks, Dave
Model: AirCard 791L|Verizon Jetpack 4G LTE Mobile Hotspot (AC791L)
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: AC791L boosters and cradles...
Hello dnyberg2
When docked in the cradle it uses the antennas of the cradle for the wifi network which does put out more signal.
DarrenM
Message 2 of 3
Jimdandy1956
I am new to the AC791L world, but I found this 4G LTE/ 3G signal antenna by Antenna Gear: https://antennagear.net/verizon-netgear-ac791l-hotspot/
Note the different cable lengths.  Hope this helps.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4894 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
