- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
AirCard 770s no battery error
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AirCard 770s no battery error
Just want to add another voice that I have the same problem.
I had one of these and it started acting up, eventually getting useless. Like everyone else, the problem seems to get worse with time. I bought a replacement unit on ebay ($10 without battery or cables). Exported the configuration info from the old unit and uploaded it to the new unit. It worked flawlessly for a couple of months but is now starting to do the same stuff.
I wish I had checked the firmware when I first received it. I don't know if it updated, but it is now running:
Firmware Version NTG9X15C_01.18.02.00
Firmware Build Date 09/30/14
Web App Version ATT_03.02.57.21
Bootloader Version NTG9X15C_01.18.02.00
With my first unit, I had some luck for a while by putting the charger on a timer, so it would charge for a couple of hours twice a day and run off the battery ther rest of the time. I may try this again for a while but expect that eventually it will deteriorate as much as the first one. My guess is that there is some temperature sensitive component inside that breaks down over time.
If anyone from Netgear is listening, I congratulate you on your planned obsolescence - it seems to be working flawlessly. However, in order to profit off of this you need to follow through by offering a new improved replacement product. Is this process hung up with the lawyers, trying to figure out how to say you fixed a problem without admitting that you have a problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I ended up replacing this with a Netgear Unite Pro 781s and it's been working great for several months. I had to trim down the SIM to get it to fit (plenty of instructions online).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I really can't believe all of you can't solve such an easy issue
The way to fix the device is to reinstall the lastest firmware upgrade but if you can find it roll back your firmware to the oldest verson possible so you can get as many of the upgrades as possible because what has happen is data corroption due to fragmention every device has that issue no matter what they tell you I know I have been a computer tech for the past 20 years some systems are better at fixing the issue as it happens but all systems have that issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have read all the posts and, in short, there seems to be no lasting fix for the "no battery" error. I'm "up there" in age so I know all of you have a lot more experience with the technical side of this issue. I called into AT&T and couldn't even get past the rep who couldn't find my phone number in the system although I was calling on an AT&T phone number. So . . . I happened on this forum. Thank you all for saving me a lot of time and money trying to fix the battery. My plan now is to take a copy of all these complaints to the nearest AT&T store and try to negotiate a replacement. I understand that equipment has failures but I also understand that companies have a responsibility to fix issues that originate in design or the manufacturing thereof. Wish me luck!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Remove battery run aircard plugged in to power. NO BATTERY.
IT DROPS OUT but works.
NOT PORTABLE.
JL
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AirCard 770s no battery error - charging cord length?
I just bought an at&t unite 770s on ebay (new - other) and didn't know about the battery problem people have been having until after I saw all of the complaints and suggested solutions about it on this site going back years... I wanted to prevent it from happening to mine so I left it plugged in to the 10 ft charging cable I had hooked up to it and took the battery out. Hotspot kept trying to boot, shutting off, trying to boot, shutting off, etc. and just kept doing that. I had almost given up when I decided to try a shorter cable. I plugged a 3 ft cable into it and then took the battery out while it was still on (I don't know if you're supposed to take the battery out while it's on but I did) and it stayed on, did say "no battery" in top right-hand corner but hotspot signal is staying on and has been working like that for hours. I have backlight set to turn off after 30 seconds to try to keep it from sucking too much juice at once. The longer cable DOES work and it charges everything I plug it into. I used the same adapter plug on both to plug into the wall. Does the cord being shorter make a difference? Should the people who are having trouble getting theirs to turn on or stay on with no battery try a shorter cord? It seems to be working for me but a lot of the suggestions people have on here work for them but not for everyone. I have no idea if this will work on a long-term basis or extend the life of my hotspot in any way and also not exactly sure why shorter cord seems to work and it continuously tries to reboot when plugged into longer cord unless electrical current is somehow stronger in a shorter cord. Anyone know why shorter cord would work so much better other than "there might be something wrong with the longer one?"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi fall,
To my knowledge, the output would be stronger because it has less distance to travel to power the unit. Like a Ethernet cable hooked up to a modem/router, the signal will be stronger if it was a shorter cable because the signal would lose signal strength as distance progress.
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi fall,
I just wanted to check in on your and see what I said has helped you. Also is your device's firmware up-to-date- with the most current version?
Please let me know. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Jason. Yes, thank you for answering my question. I don't think my firmware would even update when I first turned on the hotspot. I think it said no updates were available. so I'm not sure if it's up to date, but it still seems to be working fine. Keeping the battery out but charged in case of an emergency.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi fall,
Thank you for your response.
I'm glad that you have found a work around.
Pease let me know if you have any other questions. :]
- Jason N
- « Previous
- Next »
