× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Aircard 320 U card with 313u driver
areyouawizard
Follower
Hello
I am having an issue with the telstra 4g  320u sierra wireless card.
When i attached the device it will not show up to connect in the telsta manager as being available.
However, if i use a program called iPass which helps switch between mobile,wireless and wired connections the device is not visiible to connect but in the settings it has 2 drivers available.
As soon as i select the 320u driver as prefered it will come up in both ipass and telstra manager then i can connect without issue, but i have to do this procedure everytime i restart my laptop.....
Is there a way i can remove the 313u driver and just have the 320U WWAn???
i cannot find it in admin tools in device manager.
Telstra Aircard 320U qualcomm 3g
Windows 7 pro 64bit
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Aircard 320 U card with 313u driver
Hello areyouawizard
Yes I would try to remove one of the drivers because they could be conflicting with each other.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3965 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
