× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Aircard 781s unite pro att hotspot
dwaynemichnal
Follower
I bought this hot-spot online and they sent me a cheap Samsung charger with a tiny small wire that I'm not sure is what I need to charge it properly. What size charger do I need. I also did not get the boost charge cable. What exactly is this used for.  I don't use a PC if that helps you with ur answer. If it's important to use can you tell me exactly what I need to look for when looking to purchase it. Thank u for all ur help
Model: AirCard 781S (AT&T)|Unite Pro
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Aircard 781s unite pro att hotspot
Hello dwaynemichnal
You will want to get a 5 volt 1 amp charger.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2958 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
