× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Can't Update firmware of my Netgear MR1100
sayed1997
Tutor
Hi there ..i got Unlocked Telstra Nighthawk M1 (MR1100) and currently it running under Sim card of Zain Kuwait ....my  current Frimware is NTG9X50C_10.12.02.01 which is back on 2017/01/28 ...every time i hit frimware update it keep checking and keep like that forever ...i tried to do it Via Netgear Mobile app and every time i get pop up message telling me update error ... i even tried Factory Reset and the problem remains ... How can i update this **bleep**en Router and even there is no way that i can update it Manually ??
Model: MR1100|Nighthawk LTE Mobile Hotspot Router (AU)
Message 1 of 68
DarrenM
Sr. NETGEAR Moderator
Re: Can't Update firmware of my Netgear MR1100
You will have to contact telstra to see if they can update it.
DarrenM
Message 2 of 68
JamesGL
Master
Hi Wstyle1,
Firmwares are not available online.
Message 3 of 68
imsarsehus
Star
so how to update...i'm using m1 au telstra model, and im at malaysia also cannot update and take so long time checking
Message 4 of 68
anaspecial1
Tutor
سلام عليكم
اخوي لقيت حل ؟
Message 5 of 68
anaspecial1
Tutor
salam alikom
do u got any ansowr can help
Message 6 of 68
tark
Tutor
hi all
anyone find the answer to this, i have the same problem but from UK
Message 7 of 68
anaspecial1
Tutor
before i had the same problems but i change the sim card then i change the APN after that i can update it .
Message 8 of 68
tark
Tutor
I am using my local provider sim card and their APN.
what have you done? and how
Message 9 of 68
anaspecial1
Tutor
i was using my local sim card but we had 3 deferent company’s i change from zain to mobily after that i add the mobily APN suddenly its work then i updated the firmware after that i returned my zian sim card and its work now
Message 10 of 68
imsarsehus
Star
im also already updated, in malaysia got many telco and im try telco celcom but use another telco apn like..but it seem succesfull
Message 11 of 68
tark
Tutor
very strange
why would different telcos have different access for updates
Message 12 of 68
sayed1997
Tutor
it doesn't work for me ..i changed to Zain and ooredoo with apn noting work for me
Message 13 of 68
tark
Tutor
dont see then point in locking the updates down.
surly Ntgear can assist here and allow manually allowing the firmwares to be updated
Message 14 of 68
PepitoBird
Exact same issue here and speaking to Telstra brings no resolution.
The unit doesn't find the new firmware to install regardless of what I try including, reboots, different SIMs,  a hard factory reset.
Netgear please just allow the firmware to be downloadable.
Message 15 of 68
JSchnee21
Virtuoso
Since firmware updates are provided over the air by the carrier, and Telstra, AT&T, and a couple EU carriers are the only one's who officially support the device.  I don't really see any option but to take the device back to Austrailia and try to do an OTA update.  This may require the use of a Telstra SIM and APN.  Publically, at least, Netgear seems to be refusing to provide firmware or a tool to update it.  I had heard rumors of the launch of an unlocked commercial version of the MR1100 -- which presumably would require Netgear to provide direct support -- but I've not seen any official announcements to this effect.
Is something wrong with your current device, or do you just "want" a firmware upgrade?
You could try contacting Telstra support, but I suspect they would be unlikely to help you.  You might be able to find an Aussie friend on this board, ship them your MR1100, have him put his SIM in it, do the update, and ship it back to you.
-Jonathan
Model: MR1100|Nighthawk LTE Mobile Hotspot Router (US)
Message 16 of 68
imsarsehus
Star
bro, thanks for feedback, i got 2 unit, 1 unit already upgraded to newest firmware 10.25.01.00 on feb 2018, no need to send aussie friend just using malaysia simcard celcom telco and use apn default telstra but unit newly i purchased can’t upgrade, the checking is ok appeared current date and time, but its stated up to date actually still old firmware version, it should be appear download option to download software, maybe telstra stop server to push OTA upgrading
Message 17 of 68
JasonN
NETGEAR Employee Retired
Hi everyone,
My internal team are working on releasing a new firmware soon.
Please be patient. :]
- Jason N
Message 18 of 68
tark
Tutor
Hello Jason
Will the firmware be user upgradable or OTA.
As it currently stands OTA does not work
Message 19 of 68
imsarsehus
Star
better release interm of file instead of ota update, so we are all can download and install manually
thanks Jason N
Message 20 of 68
tsoetant
NETGEAR Expert
Hi tark,
Could you please state the PRI version, FW version, IMEI? We can check whether the device contacted our Netgear server.
Thanks
Message 21 of 68
PepitoBird
Hi there,
I require the current firmware to resolve the issue with the ethernet port going to standby.
"Could you please state the PRI version, FW version, IMEI? We can check whether the device contacted our Netgear server."
I have sent you this in a private message.
Message 22 of 68
MAGADE
Guide
Hi, guy, sorry for my english language but it is not my native language so...
May it possible to get some good news about the firmware upadte probleme.
I buyed a TESLTRA MR1100 laus desimlocked. It work properly but it is impossible to update it..
There is an executable version off firmware to got a general version like the MR1100 -EUS.
Or there is a trick to force the firmware update?
Message 23 of 68
MicW
Luminary
Hi @MAGADE
Updating the firmware via the built in update function of the M1100 is bugged for some people currently. @tsoetant in a post above requested
some information to try and work out what is causing the issue. Netgear hasn't said if they are working on a fix for it yet, so I assume they haven't worked out the problem yet. There isn't any downloadable version available to manually update it yourself.
Message 24 of 68
mdgm-ntgr
@ArodiD has mentioned that another firmware update is expected for the Telstra M1 by the end of this month. See Nighthawk M1 Data Usage
Message 25 of 68
Top Contributors
Discussion stats
Announcements
Orbi WiFi 7
