× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Connecting NETGEAR MIMO Antenna ruined by 4G modem
Retired_Member
Not applicable
I was getting good speeds on my NETGEAR 4g modem LB1120, but wasn’t getting full bars so I tried an antenna as instructions suggested, plugged in a MIMO NETGEAR connecter and it ruined everything somehow. When I saw it brought down my 50mbps speeds on my 4g modem to 1 mb, I disconnected it after trying various areas seeing it didn’t improve it. Oddly enough after I did this, all the devices on my plan where all brought down to 3g speeds. I have no idea how this antenna could have affected my phones but this happened immediately after, somehow the antenna actually ruined the connectivity in my house. Resetting devices brought back my 4g speeds on all my devices except the 4g modem. I’ve tried factory resetting it, unplugging, taking out SIM and putting it back, but I am stuck with 3g speeds when I did have 4g lte before the antenna. Rest assure I won’t ever use that NETGEAR antenna again but I really want to fix my modem that was great before all of this. The only idea I have left is replacing the modem with a new one.
Model: LB1120|4G LTE Modem
Message 1 of 3
Accepted Solutions
Retired_Member
Not applicable
Re: Connecting NETGEAR MIMO Antenna ruined by 4G modem
I was able to fix this by changing around some DNS/ IP4 instead of IP 4/6, back to 4g lite
Message 2 of 3
All Replies
Retired_Member
Not applicable
Message 2 of 3
schumaku
Guru
The antenna did't changed the router config of course.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1962 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
