- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DC112A AirCard Smart Cradle w/ Nighthawk LTE Mobile Hotspot Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an old DC112A Smart Cradle that I used with my Verizon hotspot and now have an ATT Nighthawk Mobile router. Is there a way to connect the new Nighthawk Mobile router to the old DC112A? The nighthawk has a type C usb connector and the cradle has a different usb. Would it be as easy as getting a transition usb and connect the antenna leads?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DC112A AirCard Smart Cradle w/ Nighthawk LTE Mobile Hotspot Router
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think DC112A dock will work with newer model of Nighthwak mobile hotspots.The dock's FW was customzied to work with the Verizon mobile hotspot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://www.amazon.com/gp/product/B07MJPN98H/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Thanks for your answer, but I have been working with a USB Type C male to USB Micro B female adaptor that I had from switching an old Samsung cell phone to a newer model and it worked. The only problem is that the antenna posts to not extend up to the Nighthawk from the Netgear smart cradle. So I had to purchace the antenna extensions that have an 'L' bend and go directly to the antenna from the Nighthawk rather than through the cradle unit. Here is a link to the adaptor that I believe will work that is similar to what I used. https://www.amazon.com/Adapter-BrexLink-Connector-Resistor-Charging/dp/B074SGQFDJ/ref=sr_1_12?keywor...
