× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Double NAT problem
NoName2424
Follower
Double NAT problem
Does anyone know how to get rid of double nat. I've got the lb1120 in bridge mode connected to my wifi router buy Ethernet cable. Everything works great except Xbox one keeps saying double NAT. Any help would be greatly appreciated.
Model: MR1100|Nighthawk LTE Mobile Hotspot Router (US), MR1100|Nighthawk LTE Mobile Hotspot Router (AU)
Message 1 of 7
Rainbowmercury5
Re: Double NAT problem
I too have the same problem LB1120 ethernet to WRT32X and ethernet to Xbox one X. I havent found a solution either but for some reason my sons Xbox One original design on wireless has an open Nat.
Message 2 of 7
Blanca_O
NETGEAR Moderator
Hi Rainbowmercury5
Did you set LB1120 in bridge mode?
If the xBox One connected to WRT32X, do you still have Double NAT?
Blanca
Community Team
Message 3 of 7
Rainbowmercury5
Yes, modem is in bridge mode and ethernet from wrt32x
Message 4 of 7
Rainbowmercury5
Still the same issue double nat in that configuration
Message 5 of 7
Blanca_O
NETGEAR Moderator
Hi Rainbowmercury5,
Kindly port forward the xBox One on the LB1121. Here's the reference link to enable port forwarding:
https://www.downloads.netgear.com/files/GDC/LB1120/LB112x_UM_EN.pdf [page 38 - 40].
Blanca
Community Team
Message 6 of 7
Sirguillotine
Initiate
That doesn't work for me I need some help.
Model: LB1120|4G LTE Modem
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2915 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
