× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Firmware update for Netgear AirCard 797
barrystyle
Follower
Hello all,
Today purchased a Netgear AirCard 797 to allow me to work remotely.
Found that even with perfect 4G signal; using the device to SSH to a remote VPS is near unusable.. the device itself is introducing quite a bit of lag.
Had a look at what firmware was available, as i'm not above a bit of binary hacking, to find there is nothing available (zero, zip, squat, nada..).
It is quite clear, that this product is using open source components - meaning any open source code used in this product internally, modified or not, legally needs to be available for the end-user.
I'm not seeing anything here, Netgear... thoughts thanks?
baz
Model: AC797|Mobiler AirCard Hotspot 797
Message 1 of 2
JohnPeng
NETGEAR Expert
Re: Firmware update for Netgear AirCard 797
Could you please proide your AC797's SKU name, FW version and PRI version?
Thanks
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1324 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
