× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Is there a way I can force 3G instead of LTE on Netgear LB 1120?
jmarcus789
Follower
I've been doing some testing in my area, and even with a cell booster and full bars (-56 db) on Walmart Family Mobile (T-Mobile) LTE band 12, I can only get a maximum of about 4Mbps down and 1.5 Mbps upload...  sometimes dropping below 1 Mbps. The few times I tested without the booster and only used the internal antenna, it would sometimes drop to 3G. When dropping to half bars of 3G (-95 db), I'm able to pull 8 Mbps down and 3 Mbps up. So the question.. Is there any way to force this device to only use certain bands? And any tips as to why the LTE may be working so poorly? I am in a rural area, so I wouldnt think the towers would be too busy, and I do get a small amount of signal even without the booster.
Message 1 of 2
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Is there a way I can force 3G instead of LTE on Netgear LB 1120?
Hello jmarcus789
If you go to mobile and then preferences you can select 3g or LTE only..
DarrenM
Message 2 of 2
All Replies
DarrenM
Hello jmarcus789
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5233 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
