× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
LB2120 Not connecting
alanmercer56
Tutor
Have been using the 4G router for over year without issues. I don't use failover  - so just the mobile network .
As from 2 days ago the modem is not connecting to the internet.
Message = "Mobile Broadband Disconnected"
LED = steady orange - no green (signal) LEDs
I have factory reset the device (soft and hard) - no difference
I can see the mobile network I use (Orange France) when I run a manual scan via the modem's software so the SIM is working
I can connect to the LTE network using the same SIM card in an iPhone so the SIM is OK for data
Any ideas?
Thanks!
Model: LB2120|4G LTE Modem
Message 1 of 5
cbrassel
Re: LB2120 Not connecting
Hi,
do you have any update ?
I have the same problem (with FREE provider) the 4G stop's working, and it seem's along the same date as you (i'm using it as backup so i have not detected the exact time the service disrupted).
somebody have any idea how to debug this ?
Regard's
Claude
Message 2 of 5
alanmercer56
Tutor
Hello Claude,
No - no update - the modem still does not connect to the data network (3G, 4G etc)
In the end I had to buy a new LB2120 - which works fine with the same SIM, antennae etc.
It would be great if someone on the community was able to help?
Best Regards,
Alan
Message 3 of 5
cbrassel
Finally I have resolve the problem ..
A factory configuration reset did the trick, now everything is working again ..
Message 4 of 5
alanmercer56
Tutor
I tried that - no difference! Perhaps I will try again, and again...
Glad that your issue is solved.
Alan
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3058 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
