× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
LB2120 - erases APN saved values repeatedly
jwillis84
Tutor
The LB2120 seems to have many bugs in its current firmware.
One of the most important bugs is that although it will "save" a custom APN, it will completely erase it and reset the router within 5 minutes. This makes it effectively useless for all practical purposes.
I have tried contacting Netgear to report this serious problem, but they seem well insulated from outside contact.
Model: LG2210|3G/4G LTE Gateways
Message 1 of 2
Delaponce
Re: LB2120 - erases APN saved values repeatedly
+1
I have the same issue
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2825 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
