- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
LM1200 repeatedly dropping link
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LM1200 repeatedly dropping link
Thanks, I know that the workaround works...but it's still what it is, a workaround. I need to be able to access my services (IP Cameras, etc.) while failed over to VZW. Does anyone know why this is happening in bridge mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see the same problem here. I hope this gets fixed.
Set to Routing mode and disable DHCP is NOT a good solution since you introduce DUAL NAT, that is an unacceptable solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thought I'd stir the pot again and see if anyone's gotten the LM1200 to work on Verizon in Bridge mode. Earlier in the thread, Netgear responded with a potential solution on Verizon, but haven't seen any new products or updates yet.
Everyone still using Router mode with Verizon, or just switched to another carrier?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've completely given up on the LM1200 and signed up for the Verizon Home Internet ($35/mo). Enabled bridge mode and added it to the UDM Pro as a backup. Failover works flawlessley and speed is much faster than the LM1200.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OP here,
I have similarly been forced to move to a different hardware solution as the promised resolution to stability and a functional bridge mode with the LM1200 on VZ never materialized in the intervening three years since I created this thread. In my case I went with a Peplink MAX BR1 Mini Core as it is functionally similar to the LM1200 albeit at a significantly higher price point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm in the same boat as just using this for backup, and remote access to a secondary location. Using some MVNOs and cheaper pay-as-you-go options for LTE (ie Tello), the cost is about the same as adding onto my VZ plan. Would have been nice to share the same data plan as my mobile, but probably not worth the trouble/cost at this point.
- « Previous
- Next »
