× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
LTE aggregation Needs to be updated for MR1100
Ksa3344
Apprentice
right now the carriers keeps enabling new LTE bands aggregation, for example my MR1100 eus doesn't aggregate 2300+2300+1800 which is new
but it does with 2300+2300 only to my carrier .
Also 1800+1800+700 is not supported but it is supported in Telstra version.
Is it because the firmware or the aggregation methods inside the firmware ?
Also will the MR1100 getting more updates or it will stop cause a newer version is out ?
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 9
Accepted Solutions
JohnPeng
NETGEAR Expert
Re: LTE aggregation Needs to be updated for MR1100
Sure. That would be great if you can help to collect these information. We will prioritize them for our future maintenance releases
Thanks
Message 5 of 9
All Replies
Ksa3344
Apprentice
a new aggregation worked on phone but doesn't work in nighthawk .
B28+B40
B28+B40+B3
Message 2 of 9
JohnPeng
NETGEAR Expert
Thanks for the suggestions. Could you please specify which carriers are enabling these CA combos?
Message 3 of 9
Ksa3344
Apprentice
Actually I live in Saudi Arabia .
Here we use the EUS version cause it supports all bands of our five Telecom companies here .
and the CA combos i mentioned belongs to Saudi Telecom Company known as STC .
also there is combos for defferint companies i could ask pple to give me the combos for you if its ok .
Message 4 of 9
JohnPeng
NETGEAR Expert
Thanks
Message 5 of 9
Ksa3344
Apprentice
Hello again ,
These are the working combos i got after asking arround .
B28+B40
B40+B40+B3
B40+B40+B40
B3+B3+B28
B3+B28+B40
B1+B28+B3+B3
B40+B40+B1+B3
B41+B41+B41+B41
B28+B28+B3+B1
B38+B38+B38+B38
B40+B40+B40+B40
B8+B20+B1+B3
B3+B1+B8+B38
Thank you so much for your hard work guys .
Message 6 of 9
vitaly
Tutor
To me is was a bit surprising to realize that the device does not support B3+B38 and vice versa. Is it possible to add this combination to a new firmware? The network is 250-01. With the current firmware my MR1100 EUS is much slower in this network, than iPhone 8... P.S. It seems like, the same for the MR2100 router. But I'm not 100% sure...
Message 7 of 9
Ksa3344
Apprentice
If this combo i mentioned above B3+B1+B8+B38
included with the future releases it should cover what you are asking for ,i guess.
Message 8 of 9
Mr_Khalid
Star
B3+B3+B1+B28
B41+B41+B41+B41
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 4289 views
  • 4 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
