× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR1100 LTE - VPN freqently reconnects using wireless
jazdale
I recieved a couple MR1100 LTEs to test for our company.
It is faster and works great with ethernet cable and a laptop.
However, our users also need to simutaneously connect an ipad with VPN to perform their job.
The ipad uses Cisco anyconnect VPN.
Testing 3 different ipads on 2 different MR1100s, all produced the same results.
The VPN was reconnecting every 3 to 30 seconds.
This is true using 2.4 or  5 GHz mode.
When connected to a laptop with ethernet connection, the VPN is stable.
Firmware setups say i'm on the latest with NTG9X50C_12.05.05.00
I'd love to get this resolved.
It would mean purchasing 2 dozen more for my staff.
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 4
jazdale
Re: MR1100 LTE - VPN freqently reconnects using wireless
I'm curious if there is a firmware update that addresses this issue.
Message 2 of 4
dan_vt
Having the same issues.  Wondering if you ever heard back from anyone on how to fix the issue?
Message 3 of 4
mcanderson24
I'm also experiencing the same issue - connected to Cisco VPN and it will drop connection / partially drop connection to VPN long enought to disconnect everything. All other connections work fine. Running NTG9X50C_12.05.05.00 as the firmware. It would be great if we could get this resolved.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1624 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
