× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR2100 can you run it on power only without battery
JohnS76
Follower
My Nighthawk router is generally in the same spot 99% of the time.  To preserve the life of the battery (prevent overcharging), I was wondering if removing the battery, and just run the Nighthawk M2 directly on power, was a good idea?
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 3
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: MR2100 can you run it on power only without battery
Hi @JohnS76
Welcome to NETGEAR Community!
If you plan to run the device 24/7, we recommend to power on the device with the PA only without the battery. This will avoid the battery from getting hot and impacting the device's performance.
Blanca
Community Team
Message 3 of 3
All Replies
labatt
Mentor
This is a forum for home Nightthawk routers, not mobile. For mobile go here.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
This web site is not the best designed when trying to find something.
Message 2 of 3
Blanca_O
NETGEAR Moderator
Hi @JohnS76
Blanca
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3266 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
