- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Nighthawk m1 MR1100 Firmware 12.06.07 cannot operate without battery
- Mark as New
- Bookmark
- Subscribe
- Permalink
After upgraded to firmware 12.06.07, my netgear m1 cannot operate without battery inserted.
It keeps rebooting.
Before the upgrade, it works normally just using ac adapter (with no battery inserted).
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is a known issue with the current release (12.06.07.00). The main fix in the latest release was to address the reset being experienced by some users. There should be a new FW release soon to correct the no battery problem.
Here are the release notes for the latest FW:
https://kb.netgear.com/000061333/MR1100-Firmware-Version-NTG9x50C-12-06-07-00-00
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Nighthawk m1 MR1100 Firmware 12.06.07 cannot operate without battery
Wrong forum. Go back to Community, Home, and select the correct sub-forum to post in. Someone more familiar with the product might be able to help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same problem here.
Hope the fix has helped more people than it has hurt.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wouldn't it be more helpful to describe how we can make a firmware downgrade?
- Mark as New
- Bookmark
- Subscribe
- Permalink
In hindsight, the upgrade notification should warn if a known bug is introduced to avoid the risk of upgrading firmware and then downgrading firmware.
If the above is too technically difficult to implement, a boilerplate warning to read the release notes would help those consumers feeling lazy at the time and tempted to trust in the competence of vendors.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A new release will be released soon to resolve the no battery reset. For now the recomended work around is to run with the battery installed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great! That means three to six months for the fix. My router will be melted by then
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's the best play for maximizing the lifetime of the battery?
1. Leave battery in and power plugged in and trust in the charging algorithm;
2. Attempt to run off battery power during the night and charge during the day to prolong battery life; or
3. Attempt to run off battery power during the day and charge during the night to prolong battery life?
- Mark as New
- Bookmark
- Subscribe
- Permalink
But it also comes with weaker signal strength/ lower download speed/bandwidth.
- Mark as New
- Bookmark
- Subscribe
- Permalink
"Battery charging stopped due to high device temperature." This is in a cold room on the verge of winter so possibly worse in a hot summer room.
Currently router is being used in a static location so cannot benefit from a longer battery discharge cycle. Router is due to be used in a mobile fashion in the future and presumably a similarly amusing firmware will drop to impact that mode of operation in due course.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A new firmware has been released that resolves the no battery operation. Please select check for updates on the M1.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I do a check on the unit for firmware it says I'm current, and it's 12.05.05. This is an AT&T branded device. So, 12.06.07 isn't coming up, nor whatever you are saying is now released that is newer than 12.06.07. Also, 12.06.07 is the only one available for download from the website, so if there is something newer, it's not posted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
12.06.07.00_00 is not a version I can recommend as it seems to have serious problems without the battery.
I also cannot see a newer version but would be more interested to see the release notes for any newer version and to see a consumer report that the new version is known-good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Carried out a manual check and find a 104 MB update is ready for download.
Anyone know if known-good, where the release notes are, and what the version might be?
"There's an old saying in Tennessee—I know it's in Texas, probably in Tennessee—that says, 'Fool me once, shame on...shame on you. Fool me — you can't get fooled again.'"
- Mark as New
- Bookmark
- Subscribe
- Permalink
A new firmware release soon.
I wonder when soon, is.
I do not think it should have been released with this known issue.
I use this as my main broadband.
I can't keep removing the power every time it tells me the battery is fully charged.
I don't even understand why the battery power needs to be removed when the battery is charged. Surely it has power management.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That was a fast firmware update.
It has fixed my reboot issue.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
As 12.06.07.00 is a temporary release,
let me summary my experience between 12.06.08.00 and 2 versions before :
1) It reboots faster
2) It has longer battery life, in old version, when using outdoor it cannot sustains the whole day. Now it can.
3) It can now operate without battery and does not need Quick Charge 2.0 charger. Before, if no battery inserted and not using Quick Charge 2.0 certified charger, it cannot operate. (**stock adapter works in both versions with no battery inserted, it's the case if you use other usb power source)
4) But it has weaker signal/bandwidth. In old version, it could reach 50Mbps but now it cannot, just max out ~20Mbps. Of course it may be related to my mobile LTE provider. Subject to verification and more user reports.
**I tried to rollback to see if i could get higher bandwidth. But it does not allow me to rollback (showing error 16, etc). Tried "MR-1100-100NSA..." and "MR-1100-100EUS..." version, both said invalid.
