× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M1 MR1100 external antenna setup
AndyR71
Tutor
I've just connected a Panorama 3G 4G 4GX MiMo Antenna to my Nighthawk M1 MR1100 and just wondering if I need to go into the settings and tell it to use (look for) the external antenna now? I had a look around and can't seem to find it anywhere and the signal strength hasn't really improved.
Thanks.
Message 1 of 4
KarmusDK
Apprentice
Betreff: Nighthawk M1 MR1100 external antenna setup
Remember to plug it into a wall adapter as soon as you connect external antennas. It uses a lot of power and will drain the battery completely in a few hours of heavy usage.
Message 2 of 4
Richard_J
Tutor
Re: Nighthawk M1 MR1100 external antenna setup
Do you connect the Nighthawk M1 MR1100 antenna directly to the M1 hotspot?
Model: MR1100|Nighthawk LTE Mobile Hotspot Router (US)
Message 3 of 4
JasonN
NETGEAR Employee Retired
Hi Richard_J,
Please refer to the link below and let me know if that helps fix your issue. :]
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Nighthawk-m1-Antennas/td-p/1495222
- Jason N
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 19986 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
