× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M1 - supplying external device via USB?
dk5ras
Tutor
Hi,
I wonder if it would be possible to attach an external device to the M1 by USB for power and Ethernet for connectivity, and let the M1 then power this device from its internal battery while still being able to supply other devices with WiFi connectivity. I am using such a setup with a Huawei device, but in case the M1 comes to Germany and it supports this setup I would like to change ASAP 🙂
Ralph.
Message 1 of 3
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Nighthawk M1 - supplying external device via USB?
yes this modem does have jump boost check out page 25
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf
DarrenM
Message 2 of 3
All Replies
DarrenM
DarrenM
Message 2 of 3
dk5ras
Tutor
So it appears that all other funcionality keeps untouched, just additionally the external device gets powered? This exactly is what I am looking for, thanks a lot 🙂
Ralph.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2167 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
